COMMAND Changelog
2023/10/13
Added
- We created a panel to show the introductions of all the main features to new customers
[Coming Soon]
Added
- Do not want your driver to bypass a certain area? We got you! We will support you to add an avoid area on the map when creating a route. Route will bypass the area you set.
- This is huge! You will be able to add private POI to COMMAND. You can not only add entrance and exit to the POI, and also draw a last mile approaching route for your POI. Entrance, exit and the last mile will be applied when creating the trip.
- Operator will be able to set up the navigation configuration for drivers from COMMAND web
Types of Changes
Added - for new features
Changed - for changes in existing functionality
Deprecated - permanently removed features
Removed - removed features but with plans to be rereleased
Fixed - for any bug fixes
Security - in case of vulnerabilities
Comments
0 comments
