Article Hero Background
Articles in this section
Create Groups in NavPro
Key Topics
The following guide will guide you through Creating a New Group, Setting Permissions and Routing Profiles
Creating a New Group:
  1. Log in to NavPro (or Command):
    • Begin by logging into your Trucker Path Fleet Navigation Portal using your administrator credentials.
  2. Navigate to the Groups Section:
    • Once logged in, access the "Drivers" tab from the main navigation bar.
    • Click on "Drivers" and then select "Group" from the options.
  3. Access the Add Group Screen:
    • In the Groups section, look towards the upper right-hand corner of the screen.
    • Click on the "Add Group" button.
  4. Enter the Group Name:
    • A form will appear, prompting you to enter the name of the group you want to create.
    • Enter the desired group name in the provided field.
  5. Add Drivers to the Group:
    • To add drivers to your group, click the "Add Driver" button.
    • A list of available drivers will appear.
    • Select the drivers you want to add by checking the box next to each driver's profile.
    • After selecting the drivers, click "Add" to include them in the group.
  6. Review Added Drivers:
    • The selected drivers' profiles will now be listed at the bottom of the page, showing all drivers assigned to the group.
Setting Permissions and Routing Profiles:
  1. Assign Driver Permissions:
    • Use the "Permissions" tab to assign a specific profile for the drivers in the group.
    • Select the appropriate profile by clicking the bubble next to it.
  2. Set Routing Profiles:
    • Routing profiles dictate the parameters that will guide all drivers in the group.
    • To set the default routing profile, toggle the switch on the right-hand side.
    • You can also add more profile options by selecting additional checkboxes on the right.
    • These options will be available for drivers within the app.
  3. Save the Group:
    • After configuring the desired settings, press "Save" to create the group with the selected drivers and profiles.
Was this article helpful?
0 out of 0 found this helpful
Comments
0 comments
Additional Resources
  • Our helpline hours:
  • Follow us on our socials
