Introduction
We’re going to walk through the steps to push routes from your Samsara portal to Trucker Path.
Prerequisites
- Your Samsara account has already been linked to your Command account
Guide: Connect your ELD to Command - The driver has already been added to your command portal
Summary
Configuring your Command
Log into your Command portal
Navigate to ELD
Ensure your Samsara is integrated, if not follow this guide
- If you assign routes to a truck click Trucks:
- Click Assets
- Navigate to To Connect --> Select the trucks you want to connect --> Click Connect
- You can check the Connected tab and confirm that your truck(s) has been connected.
- Click Assets
- If you assign routes to drivers click Drivers:
- Click Drivers
Select → To Connected
Find the your driver and click Connect Driver in Command
Select the Driver and click "Save”
Creating a Route in Samsara
Let’s open up Samsara
Find “Dispatch” then select “Routes”
Click Create New Route
Enter all the details for the route (Use Vehicle if you assign routes to Assets)
IMPORTANT: Assign the correct driver/vehicle to the route
Complete
That’s it! The route will be sent to your driver via the Trips tab in the Trucker Path App.
Comments
