Article Hero Background
Articles in this section
Using the Trucker Path URL Launcher Schema
The URL Launcher Schema lets third-party applications open the Trucker Path app and initiate truck-safe navigation. You can build a route by passing one or more stops, defined by latitude and longitude, into the app.
Once launched, the driver simply taps Confirm and Navigate to begin the route.
📍 Supported Inputs
You can pass the following types of stops via URL:
  • Starting Point (optional)
    saddr (iOS) or s_addr (Android): latitude,longitude
  • Destination (required)
    daddr (iOS) or d_addr (Android): latitude,longitude
  • Waypoints (optional)
    paddr (iOS) or p_addr (Android): one or more latitude,longitude values, separated by |
Note: All coordinates must be in decimal format. Only lat/long values are supported (no addresses or place names).
📱 iOS Schema Format
truckerpath://cal_route?saddr=%f,%f&daddr=%f,%f&paddr=%f,%f|%f,%f|...
Examples:
  • Only destination:
    arduino
    truckerpath://cal_route?daddr=35.353112,-119.040104
  • Start and end points:
    arduino
    truckerpath://cal_route?saddr=34.353112,-118.040104&daddr=35.353112,-119.040104
  • Route with 2 waypoints:
    arduino
    truckerpath://cal_route?saddr=34.353112,-118.040104&daddr=35.353112,-119.040104&paddr=33.353112,-117.040104|32.353112,-116.040104
🤖 Android Schema Format
perl
truckerpath://cal_route?s_addr=%f,%f&d_addr=%f,%f&p_addr=%f,%f|%f,%f|...
Key Differences:
  • Use underscores (s_addr, d_addr, p_addr) instead of (saddr, daddr, paddr)
  • d_addr is required, s_addr and p_addr are optional
  • If no s_addr is provided, Trucker Path uses the driver’s current location
Examples:
  • Only destination:
    truckerpath://cal_route?d_addr=35.353112,-119.040104
    truckerpath://cal_route?s_addr=34.353112,-118.040104&d_addr=35.353112,-119.040104
    truckerpath://cal_route?s_addr=34.353112,-118.040104&d_addr=35.353112,-119.040104&p_addr=33.353112,-117.040104|32.353112,-116.040104
đź’» Sample Android Code
val intent = Intent( Intent.ACTION_VIEW, Uri.parse("truckerpath://cal_route?d_addr=35.353112,-119.040104") ) startActivity(intent)
Questions?
If you have any questions regarding this topic or any others, please reach out to our Support Team via email at fleetsupport@truckerpath.com.
Was this article helpful?
0 out of 0 found this helpful
Comments
0 comments
Additional Resources
  • Our helpline hours:
  • Follow us on our socials
