Article Hero Background
Articles in this section
Routing Profiles
In this article, you'll learn how to add routing profiles to your account, ensuring drivers follow directions based on specific vehicle dimensions.
Step 1: Begin by clicking on the More tab located in the upper right hand corner of your screen. Then select Routing Profile.
Step 2: You'll see a list of all current routing profiles in your system. To add a new one, click on Add New Setting.
Step 3: Name your routing profile and enter the vehicle's height, weight, width, and length for the max weight. You can also adjust the axles and number of trailers.
Step 4: If your truck transports hazardous material, select the corresponding option. This will adjust the routing accordingly.
Step 5: Use the Avoid areas feature to add areas you want to avoid. Click on Add Avoid Areas.
Step 6: Name the area you want to avoid and click Save.
Step 7: Click on the map and then click Add. A red square will appear.
Step 8: Resize the square or change it to a polygon if needed. After setting this, click Apply Changes.
Step 9: You can add preferred lanes by selecting specific routes for drivers. Add waypoints on the map and hit Save.
Step 10: Assign this routing profile to specific groups. Once completed, hit Save.
Step 11: Your new routing profile will now appear in your Routing Current routing Profile list.
To edit a previously created profile, right click on the Action button on the right hand side and click Edit. To remove a profile, click Delete.
Was this article helpful?
0 out of 1 found this helpful
Comments
0 comments
Additional Resources
  • Our helpline hours:
  • Follow us on our socials
