Summary
The following article will provide you with a step-by-step to use The Preferred Lanes feature in Command & NavPro.
Get Started
- Start by logging into the Trucker Path Fleet Navigation Portal.
- Navigate to the dashboard where you manage your fleet's navigation settings.
- Click on the "More" button in the portal’s main menu.
- From the dropdown, select "Routing Profile" to access the driver profiles.
Editing a Driver Profile
- Locate the driver profile you wish to add the preferred lane to.
- Click on the ellipsis (three dots) on the right-hand side of the profile.
- Select "Edit" to open the profile settings.
Adding Preferred Lanes
- On the profile edit screen, find the option labeled "Add Preferred Lanes."
- Click on this option to begin creating a new preferred lane.
Naming the Preferred Lane
- A prompt will appear asking you to name your preferred lane.
- Enter a descriptive name for the lane, and click "Save."
Setting the Preferred Lane on the Map
- Use the search bar or navigate the map to locate the area where you want to set the preferred lane.
- Once located, click on the "Add Road Path" button.
- An orange waypoint will appear on your cursor.
Placing Waypoints
- Place the first waypoint on the desired starting point of the preferred lane.
- Continue to add waypoints along the desired route, ensuring that each waypoint is placed on the correct side of the road for proper routing.
Adjusting the Route
- If you need to remove a waypoint, click the minus button next to it.
- Review the generated path to ensure accuracy.
Saving the Preferred Lane
- Once you are satisfied with the preferred lane, click "Save."
- The preferred lane will now be applied to all drivers using the associated routing profile.
Confirm
- Return to the routing profile overview to confirm the changes.
- Ensure that the preferred lane is correctly associated with the desired drivers.
Congratulations, you have successfully created a preferred lane! This preferred lane will guide your drivers along the designated route whenever it intersects with their planned path.
Thank the user for choosing Trucker Path and remind them to reach out for any further assistance.
Comments
