The following guide will walk you through managing permissions for Operators and Drivers.
Adjusting Permissions for Operators:
Log in to the Fleet Navigation Portal:
- Begin by logging into your Trucker Path Fleet Navigation Portal using your administrator credentials.
Navigate to Role Permissions:
- Click on the "More" tab in the main navigation bar.
- From the dropdown menu, select "Role Permissions."
Access Operator Permissions:
- At the top of the Role Permissions screen, you’ll see two tabs.
- Click on the "Operators" tab to manage permissions for users with access to the Trucker Path back office system.
Adjust Operator Permissions:
- In the Operators tab, you can adjust access to specific features for all operators.
- You can restrict their ability to edit, view, or even completely remove access to certain tools.
- Once you’ve selected the desired settings, click "Save."
- The adjustments will be applied to all operators in the system.
Adjusting Permissions for Drivers:
Access Driver Permissions:
- Navigate to the "Drivers" tab within the Role Permissions screen.
Create a New Permission Profile:
- To create a new profile, click on "Add Permission Setting" in the upper right-hand corner of the screen.
- Enter a profile name in the provided field.
Configure Driver Permissions:
- After naming the profile, select the desired options for the profile.
- You can configure settings such as Navigation Settings, Messaging Options, and Routing Settings.
Set Default Profile (Optional):
- If you want this profile to be the default for all drivers added to the fleet, select the "Default Profile" option.
Save the Profile:
- Once you’ve finished adjusting the settings, click "Save."
- The new profile will now be available to apply to drivers within the fleet.
Questions?
If you have any questions regarding this topic or any others, please reach out to our Support Team via email at fleetsupport@truckerpath.com.
Comments
