Article Hero Background
Articles in this section
Installing Offline Maps
Option 1: Download over Wi-Fi with certain connections blacklisted
  • Let your customer success manager know the exact Wi-Fi name you would not want the Offline Maps to download from. We will blacklist that connection so it will only download on other connections.
  • Within the Fleet App, Navigate to Me tab, tap on Offline Map​
  • Tap on Get Your Map Now​
  • Select the United States Map
  • Tap on the Download Icon
  • The map file size is 10 GB, the download may take up to 1hr, pause and resume as necessary​
  • ​Successfully downloading the Offline Map will show under Downloaded
Option 2: Install via a wired connection to the device
  • Plug-in external USB drive to tablet
  • Within Trucker Path, go to Me tab, tap on Offline Maps​
  • Choose Install Map from Flash Drive​
  • On the top left menu icon, Open from the plugged-in external Drive [NO NAME]​
  • Go to the folder named TruckerPath
  • The Truckerpath filder contains all the data files required to transfer Offline Maps. Press SELECT without tapping on the individual files.
  • The transfer will take around 10min to complete installation. Do not quit the App during this process. After successfully installing, it will show under Downloaded​​​​
Questions?
If you have any questions regarding this topic or any others, please reach out to our Support Team via email at fleetsupport@truckerpath.com.
Was this article helpful?
0 out of 0 found this helpful
Comments
0 comments
Additional Resources
  • Our helpline hours:
  • Follow us on our socials
